Perform the following procedure to configure emergency call service location of local LLDP-MED on specific ports.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure emergency call service location:
    lldp location-identification ecs-elin WORD<10-25>
Configuring emergency call service location on port 2/1–2/3:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabitEthernet 2/1–2/3
Switch:1(config-if)#lldp location-identification ecs-elin 123456789
The following table defines parameters for the lldp location-identification ecs-elin command.
Variable
Value
WORD<10–25>
Specifies the emergency line information number for emergency call service.
